Altra magagnetta, il sedile lato passeggero scorre sulla sua guida azionando la leva di regolazione però ne scorre ne si ribalta azionando la leva per far salire i passeggeri dietro, non funziona neanche la leva per regolare lo schienale, c'è qualche manovra da fare per sbloccarlo?
ci si potrebbe provare?
1. Get into seat
2. Push both side adjusting handles forward/down
3. Using your body weight, recline the seat all the way back
3. Now, raise your whole body up, so you're now sitting on the back of the seat, placing your bum where your shoulders normally be would be.
4. Pull both side adjusting handles /levers UP while forcing, bouncing, and pushing your body weight down.
( If you're not heavy - resisting putting your feet on the dash in hope of more force - this is all about leverage, so keep bouncing your weight)
5. Keep pushing down until you hear the crack.
6. As you're sitting on it, the seat back will suddenly give a couple of inches.
7. Resume the normal sitting position and the seat back should automatically spring forward with you.
8. You can now use the side adjusting handles/levers to click the seat in the position of your choice.
On 15/3/2017 at 10:50, alex1974 dice:
forse ti si è proprio rotto il tirante che aziona il meccanismo :/
