Mini Coupè
Ospite nordschleife
si ho capito,ma non credo che sparino dei dati a caso,eppure...
comunque se la jcw normale fa 6,6 sec...la coupè pesando di meno è normale che abbassi il tempo di 4 decimi,che poi non credo che il guidatore medio senta la differenza..
Ma sul consumo non sparano dati a caso eh. Loro si attengono al ciclio di omologazione europeo. Che poi quest'ultimo è sballatissimo e non conforme alla realtà è un'altra questione.
ragazzi bmw-press da altri prestazioni......
  • MINI John Cooper Works Coupé: Four-cylinder petrol engine with
    twin-scroll turbocharger and direct injection, plus numerous technological details carried over directly from motor sport.
    Displacement: 1,598 cc,
    output: 155 kW/211 hp at 6,000 rpm,
    max. torque: 260 Nm/192 lb-ft at 1,850 – 5,600 rpm
    (280 Nm/207 lb-ft with Overboost at 1,700 – 4,500 rpm).
    Acceleration: 0–100 km/h (62 mph): 6.4 seconds,
    top speed: 240 km/h (149 mph).
    Average fuel consumption according to EU standard:
    7.1 litres per 100 kilometres (39.8 mpg imp),
    CO2 emissions: 165 g/km.
    MINI Cooper S Coupé: Four-cylinder petrol engine with
    twin-scroll turbocharger, direct injection and fully variable valve management based on the BMW Group’s VALVETRONIC technology.
    output: 135 kW/184 hp at 5,500 rpm,
    max. torque: 240 Nm/177 lb-ft at 1,600 – 5,000 rpm
    (260 Nm/192 lb-ft with Overboost at 1,700 – 4,500 rpm).
    Acceleration: 0–100 km/h (62 mph): 6.9 seconds,
    top speed: 230 km/h (143 mph).
    5.8 litres per 100 kilometres (48.7 mpg imp),
    CO2 emissions: 136 g/km.
    MINI Cooper Coupé: Four-cylinder petrol engine with fully variable valve management based on the BMW Group’s VALVETRONIC technology.
    output: 90 kW/122 hp at 6,000 rpm,
    max. torque: 160 Nm/118 lb-ft at 4,250 rpm,
    Acceleration: 0–100 km/h (62 mph): 9.0 seconds,
    top speed: 204 km/h (127 mph),
    5.4 litres per 100 kilometres (52.3 mpg imp),
    CO2 emissions: 127 g/km.
    MINI Cooper SD Coupé: Four-cylinder turbodiesel with aluminium crankcase, common-rail injection and variable turbine geometry.
    Displacement: 1,995 cc,
    output: 105 kW/143 hp at 4,000 rpm,
    max. torque: 305 Nm/225 lb-ft at 1,750 – 2,700 rpm.
    Acceleration: 0–100 km/h (62 mph): 7.9 seconds,
    top speed: 216 km/h (134 mph).
    4.3 litres per 100 kilometres (65.7 mpg imp),
    CO2 emissions: 114 g/km.
  • Exterior dimensions:
    Length: 3,728 millimetres (MINI Cooper S Coupé,
    MINI John Cooper Works Coupé: 3,734 millimetres)
    Width: 1,683 millimetres
    Height: 1,378 millimetres (MINI Cooper S Coupé,
    MINI John Cooper Works Coupé: 1,384 millimetres)
    Wheelbase: 2,467 millimetres
NOTARE COOPER sd COUPE'... new_20.gif qui si venderà alla grande..
ragazzi certo che in previsione della nuova MINI nel 2013, una MINI con il tetto tagliato non so se la comprerei...
..anche se mi piace molto!
cioè volgio dire, costa un bel pò e dopo poco più di un anno avrà la linea della "vecchia" MINI...
Modificato da MINId
Vedo che hanno avuto il buongusto di non fare la la One coupe post-8-1120395070.gif
Ci pensavo un attimo.... chissa` quanto gli e` costato fare questa mini (che alla fine ingegneristicamente sembra poco piu di una variante della hatchback) e quindi che prospettive di vendita hanno.... perche` me la vedo moooolto come fighetto machine..... ho i soldi e volgio la mini ====> cooper S ho i soldi e voglio la 2 posti =====> mx5, mr2, Elise, slk, TT..... faccia fatica a immaginarmi il cliente tipo, se sacrifico la possibilita` di portare due passeggeri volgio qualcosa di cattivissimo.... non certo TA! Poi conoscendo la BMW la metteranno nel range di prezzo della 911! post-8-1120395070.gif Vedremo!!!
Modificato da Ludo91
Ovviamente sarà una vettura di nicchia. Quasi sicuramente su ogni auto venduta bmw si farà un bel guadagno. Alla fine si può dire che hanno modificato solo la carrozzeria.
quoto..aggiungerei che hanno modificato solo il tettino...
bhè...nn capisco perche se hanno concepito un motore nuovo da 250 cv , lasciare sulla jcw il 211 , a me sta notizia sembra na bufala , anche se si leggeva da tempo che la coupè sarà impiegata nelle corse..., tranne se è una cosa altamente voluta non aumentare i cavalli su una stradale , dato che il bollo per una MINI poi salirebbe davvero alle stelle....!
i prezzi sono quelli che si sapevano..., anche se aspettiamo fonti migliori...!
Magari con 250cv non riescono a stare dentro con le emissioni.
cippy ma guarda che anche nelle gare , manifestazioni e trofei di piccola portata ci sono delle leggi molto serrate sulle emissioni , nn solo l'uso stradale va curato! cmq ormai la circolare parla chiaro..., io speravo in un motore nuovo per questa jcw coupè...,
23k e 33 K euro per una due posti TA?!?!!??!?!new_12.gif La venderanno solo perche` fa molto figo a gente che di macchine ne capisce poco, perche` nessun pistola va a spendere quella cifra (anzi, ben di piu visot ke in bmw anche il volante e` optional!) per un incrocio che ha due posti ma ha la TA !!!!
35MILA euro da spendere in una sportiva ci prendo un Elise clubsport nuova..... una Evora usata poco che ha pure 4 psoti e quella roba se la dimentica!
23k??? e ci prendo una tras-cooper da 120 cv a due posti??? Mx5!!!!!!
Col marchio mini vendi anche macchine con le ruote quadrate di marmo, su questo non si discute, complimenti a bmw per il design che e` carino ma per quanto mi riguarda e` poco piu che un esercizio di stile......
Pero` we.... e` bella e le macchien si celgono col cuore quindi vendere la venderanno....
Just my two cents ;)
La bmw ha come scopo fare soldi quindi ha fatto benissimo a farla, dal momento che riuscira` a venderla e a farci tanti soldi, poi siccome a molte pesone piace ci sta... post-8-1120395257.gifpost-8-1120395257.gif
Quello che intendo io e` che e` una macchina sicuramente bella, ma che presa nel suo insieme non e` "ne carne ne pesce", e` poco piu di un esercizio di stile che grazie al marchio mini si vendera` bene..... che il prezzo sia altissimo rispetto al reale contenuto (una mini con due sedili in meno e il tetto tamponato) e` di poco conto su di una macchina stramodaiola...
avere due posti invece che 4 e` diciamo scomodino, pero` su una macchina VERAMENTE sportiva (cioe` una macchina con doti dinamiche di primo piano, non che faccia 234324 kmh) si puo` tranquillamente accettare.....
Ma una macchina VERAMENTE sportiva non e` una trazione anteriore.....
Mi sembra una cosa sicuramente bella ma non tanto coem macchina, piu che altro coem accessorio fashion... insomma uno che vuole una SPORTIVA non prende una mini col tetto schiacciato! perche` alla fine e` quello che e`!
E` come una mini che assomiglia ha una supersportiva, assumendo le scomodita` di quest ultima ma non i pregi, perche` sempre una mini resta..... macchina briosa e divertente, ma anni luce da certi capolavori di dinamica.... Se qualsisi altra casa la avesse presentata (quindi non marchiata mini) il coro di "ma che ###### me ne faccio di sta roba" sarebbe stato unanime
QUesta e` un opinione di uno che le macchine le valuta prima per la dinamica, secondo per la praticita e terzo per l estetica! siccome per molti altri l ordine e` diverso il successo e` assicurao
Vero, ma credo siano molto più permissivi.
Non fredo che le varie categorie gt2/gt3 rispettino le euro 5.
Ma una elise è molto meno sfruttabile di una mini coupè.
E poi il mondo è bello perchè è vario.
A me non sembra un furto, ma un prezzo giustificato da molti motivi.
